350TacoZilla
- 1
- 16
- Hancock MD
sorry no I sold axles to friend before I ever got the calipers on, i can give you part # and info on the rotors. I had a local machine shop open up the inside hole on rotor to fit over hub and then drilled hub from backside and threaded holes to bolt rotor on.
- napa NB 4885858
# of Bolt Holes : 10
Bolt Circle Diameter : 7.25"
Brake Rotor Diameter : 15.37"
Brake Rotor Discard Thickness : 1.42"
Brake Rotor Thickness New : 1.54"
Brake Rotor Type : Disc Brake Rotor Only
Center Hole Diameter : 6"
Height : 3.4"
Maximum Lateral Runout : .004"
Mounting Type : Type L - Rotor Only. The Rotor Is Mounted Inboard Of The Hub. The Hub & Rotor Sections Are Bolted Together. Replace The Complete Assembly If Hub Flange Is Bent Or Damaged. See Diagram For More Information.
Vented / Solid : Vented
