M35a3 air problem???
jcappeljr
27
Delta, PA.
Hey,Hopefully someone can help out.My a3 wont build up air sometimes and it seems to be coming out of the ctis air valve under the bed.you can start it some times and it builds air right up and sometimes it doesnt.The ctis controller above the steering wheel doesnt come on and the screen has something on it sometimes but it isnt readable.When I picked the truck it had a flat tire,I aired it up enough to get going and it seemed to air itself upgoing down the road,All the tires have been holding air.Any help would be appreciated.thanks, john
jeep-Jeep
Liberty Hill Texas
are you sure it is the ctis valve and not the air drier .
a bad drier will make the compressor shut down and not produce air .
It happened to me at a air show this weekend .
a new drier fixed the problem
jcappeljr
27
Delta, PA.
I am new to thae a3s,I just glanced at it ,it could be the air drier.I forgot these trucks have air driers.
AceHigh
31
Lake City FL
My money is on the dryer also. In addition for trouble shooting purposes turn off the air assist steering valve on the firewall, just to make sure it is not the problem. The air assist vents into the air intake I think, and air escaping can do it quietly.
jcappeljr
27
Delta, PA.
i can get one from my local commercial truck parts guy.It sounds like the air drier,It puzzles me because it works fine one then it wont build up air the next day.
R Racing
St. Leonard, MD
Yes try to remove the connector from the back of the CTIS up on the steering wheel and see if it still does it. If it does than its your dryer.If not than I would say its your CTIS. I'm thinking dryer as well from what it sounds like.
sierra117
Isanti, MN
I believe the valve on the air dryer that releases the moisture from air system is getting stuck open try pushing it in when it leaks. I have had this issue with air dryers driving semis. But keep in mind it might be a temporary fix though. You may need to rebuild or replace the air dryer
jcappeljr
27
Delta, PA.
Also when I turn off the ignition switch it lets out a large release of air,Are they supposed to do that?
R Racing
St. Leonard, MD
When the CTIS is pumping up the tires it lets out a big blast andf makes a noise of what sounds like a sick cow lol then it stops for a few min and does it again until all you tires are pumped up . It cycles on when the air pressure is over 90 but can drop to near 60 during the cycle.
jcappeljr
27
Delta, PA.
I guess I am gonig to work on it after work tommorow,Ive been busy painting,now its time to do some wrenching.
