Mushroom elbow.
jwaller
19
Columbia, SC
ever since I went ot the meet in atlanta a week ago and saw Rmgill's deuce with the mushroom elbow I had to do it. so yesterday I went to napa and got pt# 41373 and bolted it right up. took about 10 minutes including paint and clamp.
houdel
11
Chase, MI
NAPA is not all that great for parts, besides being expensive. Go to your local parts store and tell them you want a 4"ID x 4"OD elbow, that should get you want you need reasonably cheaply ($25-$35 bucks or so). Plus, then you can pull the mushroom if your engine needs a little shot of ether to get it started. My Deuce has the ether start kit installed, I suspect the ether cannisters are a lot more than I want to spend!
Djfreema
Santa Clarita, Ca
I bought mine on Ebay for 19.99, turns out it was shipped from memphis equipment. Should help out with keeping the air filter dry when driving in the rain or snow.
jwaller
19
Columbia, SC
my bad the napa # is 41378 with a upc of 8638741378. I wrote it down wrong.
and if I remember right it wasnt that expensive esp for being from napa.
ktm380
Pueblo West, CO
Thank you! I will try napa this weekend.I may even try some of the local semi-truck shops around, they should use that size alot I think.
houdel
11
Chase, MI
4" exhaust pipe is pretty standard and in stock at most shops that sell truck parts. 3-1/2" is a different story, usually needs to be special ordered.
Difreema - $19.99 for a 4" elbow is pretty fantastic, the shops around here are in the $30-$40 range. Are you sure about that price, ESPECIALLY from NAPA, or are you just suffering from CRS? The NAPA on line store lists it at $33.99
Boatcarpenter
Marlborough, NH
Most of you probably know this, but I didn't until a little while ago. If you are a member of AAA, Napa gives a good discount. When I did a coolant flush I bought my antifreeze there and saved 7or 8 bucks with it.
hndrsonj
Senior Chief/Moderator
375
Cheyenne, WY
What is the red light next to the drivers side turn signal on dueceswild's M35?
