welldigger
- 17
- 38
- Benton LA
Seeing those nice seats reminds me I need to get off my butt and do my seat upgrade.
If in the cab you can only aim front right, on the step the barrel can be aimed more towards the front of the truck. This is version 2.0, improvements could be made.Looking good! I like the rifle mount and seats. What kind of sweep range do you get with the rifle mount with the exhaust stack being right there? Seems like you'd only be able to aim to the front right of the truck and back.
Its one of the BEST things you can do for the deuce!Seeing those nice seats reminds me I need to get off my butt and do my seat upgrade.
My seats aren't the way cool seats that m-1028 used. Just some n.o.s hmmwv seats and a A3 drivers seat base. Turns out hmmwv seats are a direct replacement for a3 drivers seats. Anyways my truck is equipped with the super luxurious box seat with worn out cushion. I certainly can't do much worse!Its one of the BEST things you can do for the deuce!
I really appreciate it, taking my time and making the truck better and more useful for my needs was the goal. Still a lot of work left but at least it's a running driving truck.OK OK I will have to just say it, YOU are doing this truck the correct way rebuilding the front diff. can never hurt as far as the hood oh well brain fart. You seem to be putting some good thought into how and what you want from this truck in the end I admit I am somewhat of a SNOB when it comes to altering an already PERFECT IN EVERY WAY TRUCK such as a Deuce and good lord BOBBING it, Elvis is turning over in his grave! You have given me a little perspective on this, I think most of MY problem is that I see so many HACK/BUTCHER patch together BOB jobs that do nothing more than destroy a decent truck! You are doing the Deuce some justice by actually making it into what your want without disgracing the truck and its heritage in the process! Keep the pics coming and I am confidant you will have a beautiful truck when completed!
KK
Thanks! Any seat in my opinion is better than the stock seats, get them suckers installed, your back will thank you.My seats aren't the way cool seats that m-1028 used. Just some n.o.s hmmwv seats and a A3 drivers seat base. Turns out hmmwv seats are a direct replacement for a3 drivers seats. Anyways my truck is equipped with the super luxurious box seat with worn out cushion. I certainly can't do much worse!
M-1028, this is gonna be an awesome truck! Doing a frame off build may not have been your original plan but the end result will be so much nicer. Keep up the good work!!!
Between work and weather I do what I can. But yes, new seats are the next project. I hunted forever for an a3 drivers seat base. Not easy to find as it turned out. At least at a reasonable price. I wanted the a3 base because it was a bolt in fit and I hate the a2 springer base.Thanks! Any seat in my opinion is better than the stock seats, get them suckers installed, your back will thank you.
It's bolted about 4' from the cab towards the back. It's about a foot in front of the rear axle. I'm trying to post more pics but it's not letting me.Is that Braden winch going between the frame at the rear of the truck?
What kind of issue's? I figured the copper would be more of a problem due to it being so rigid. Thanks!I have heard of guys having issues with non-copper lines coming off the air compressor, you might want to keep an eye on that line for a little while. I like the "boot guard" in the last pic!
