part id
rottiedog
New Bern, NC
Ok, I don't have a picture of it but I was trying to figure out my shifting issue and was checking vacuum lines when I found something. First, I found a nest under the intake. Next, I found what looked like a blown resistor. Just behind the intake and next to the vacuum pump is a big engine harness. Coming out of there is two wires hooked to a black "connector" that had what appeared to be a resistor. One of the legs looked blown.
Any idea what this thing is? What does it affect? Nothing seems to be broken so I am assuming that it goes to something unused like the radio rack.
85 M1009
FMJ
37
Las Cruces, NM
The problem I have had is the switch mounted on the accelerator pedal bracket under the dash not working, check it with a meter make sure it opens and closes (continuity) I'll go take a look at my 1009, but the stuff that goes through the firewall near the Vac pump is radio stuff, mine is unplugged.
Croatan_Kid
New Bern, NC
I don't know what that resistor does, but I was definitely wondering about that myself while I was looking for burnt fuseable links. I didn't know if they were all just stuck in that connector and bent back or if it was just mine....glad to know it aint just me!
