joey
- 0
- 0
- North Bend Oregon
After running into a problem with my filters being bypassed I finally got around to installing somthing that I know works. now if i could only get the stupid truck to run right..
I Peiced it together from work, all the tugboats ive seen run raycors. An old cheif engineer had it as spare parts incase something broke he quite and i took his raycor.Joey,
Is this something you acquired recently? If so, where did you find/get it and how much?
Bjorn,
Is this the unit that you were looking for the glass bowl for and found out that a mason jar was same size and would work?
Ok, final 2 questions everyone knew was coming................ (4th cup of coffee at 5 in the morning).
Is this a viable alternative to the 3 filters currently on the deuce or just replacing the primary filter?
Is there a filter finer than the 20 micron available?
