1800 Diesel
TM only mentions removal of the center bolt (with 5/8" hex) prior to pulling the wheel. Tried to search SS for relevant posts, but couldn't locate the info I'm looking for. In order words I want to be sure that the center bolt is the ONLY one I need to remove before setting up the puller. I believe the other 6 bolts are for something else like the damper & it will come off attached to the wheel--is this correct? Figure 37 in TM 24P seems to indicate this but wanted to be sure before I damage something.
Also, for those of you who have already done this job, I wanted to ask about the amount of force needed to pull the wheel. Is it an interference fit, a slip fit or what? I've applied PBB to the crankshaft and started to pull pretty hard but no movement. Also, on the unit I'm working on I noticed 2 of the other bolts are finger tight. Will I be able to get to the "back side" of these once I remove the wheel?
Thanks.
Thanks.
