- 4,210
- 37
- 0
- Las Cruces, NM
I'm swapping out a sprag for an air shift and noticed a difference between the drivers side case mounts. The airshift is on the jack, the sprag is in the truck. Can I use the sprag mounts with the airshift?, or do I need to swap out everything including the brackets on the frame? the undertruck pics with no t-case are from the donor truck.
