Time to operating Temp
BFR
Rocket Surgeon
2,330
42
North Georgia
I was suprised at how fast my truck reached operating temp this morning when I took it for a spin at 20 degrees and am curious how long it takes different trucks to reach operating temp in various conditions.
this morning I was at 180 after 5 minutes of idle and 5 miles at 20 degrees.
I have nothing but a winch, and bridge plate, blocking the radiator.
I do not have the heater installed.
91W350
57
Salina, Kansas
My 72 would not get there without a radiator cover below 20 degrees. My 68 sounds like your truck. My 71 must need a new thermostat, it never gets warm when it is cold out.
rlwm211
19
Guilford, NY
If I start my deuce and let it idle, or run at just above idle, it takes at least 30 minutes to warm up.
If I start it and after a minute or two start towards town on the flats it takes about 5 miles to get to at least 160.
If I start my deuce and let it idle and then head up the steep hill behind my house it is warm by the time I get to the top. This is about 3.5 miles but some of it is 3rd gear or even 2nd that is how steep it is and since I have to turn over 90 degrees to get on the road I don't get a run at it.
If I am driving my deuce at highway speeds it holds a pretty steady temp between 160-180 depending on the grade and the ambient temps. I have seen nearly 200, but that was after a long grade pulling a trailer in 90+ degree heat.
My radiator is pretty new and clean so bugs or dirt are not a factor.
RL
