gunner_bear
- 1
- 0
- grand haven mi
where is a good location to purchase the shear pins for a deuce? $4-5 each seems a bit pricey on these
Looking to buy 10-12 of them, thanks
Do you really want the cheapest with something like a shear pin? I prefer to spend a reasonable amount of $ on things like parachutes, fire extinigishers, birth control, fuses, and shear pins. No need to skimp when paying for items like these..
Sometimes cheap costs alot in the end,,,,,
Even if you spend big money on a shear pin, how do you know your getting the proper grade number of aluminum for your "fuse". I've never seen a shear pin come with an attached, material certifiction number. I see them advertised and sold as "M35A2 Aluminum winch sheer pins"Do you really want the cheapest with something like a shear pin? I prefer to spend a reasonable amount of $ on things like parachutes, fire extinigishers, birth control, fuses, and shear pins. No need to skimp when paying for items like these..
The 1/4 size is a touch small, EVERY TIME you use the winch, you are wallowing out the holes causing more and more slop, not only will this cause more BOLT breakage but PREVENT the use of the CORRECT PINgo to the local hardware store and get the cheapested 1/4 inch bolts and that should do the trick bolts are just a little harder than the shear pins but a whole lot cheaper just remember to take along a shear pin for the correct length
A ROLL PIN, WILL NOT SHERE like a shear pin, It will crack, break, deform, but not shear (unless under a HIGH shock load), a roll pin will KILL a winch and the protected connection.My deuce came with the pin sheared. I replaced it with a "roll pin" also sometimes called a "spring pin" They are steel, but hollow. Have not checked the torgue to shear it compared to the aluminum.
