wsucougarx
- 65
- 48
- Washington State
Back Up Light Switch and Status Light Project
This is the start of my wiring project for this truck. First order of business was getting the back up light switch/status light completed. The bracket used was nothing more than an M35A2 Airshift Lever bracket, M939 series battery switch, Low Air Pressure Indicator Light kit,and a large stainless steel washer. This project was a piece of cake. I added the status light as to not blind the drivers behind me or accidentally leave the light on after shutting her down for the night. I won't explain how it was all assembled, the pics will answer the questions. The large stainless steel washer was used because the rotary switch is offset in the bracket. To cover up the obvious offset, I just covered it up with the washer.
Pics:
1- Parts needed for the project
2-Oops same pic
3-Everthing assembled
4-Different angle
5-I don't have it wired quite correctly. However the idea is to have the status light in between the switch and the power out. As electricity flows from the switch to the rear back up lights, it'll light up the status light. The socket I'm pointing to will have the connector wire that feeds the rear lights. Simple enough.
Pics:
2-Oops same pic
4-Different angle
