Durango_USMC
- 0
- 18
- Indianapolis, IN
I'll be bringing an ATV as well, nothing highspeed or all that big, just a little 250cc to run around on for the day. Not sure if I'll be bringing the M1008 or not at the moment.
You can chuck the rope up in my truck........wait till you see all the pretty lights( and all the other new goodies).......muahahaha!!!I have an extra, long recovery rope if some one wants to carry it for the rally. Usually Dan carries it and he is not going to be there.
darn... thats some bad luck... I was looking forward to seeing him..Looks like eagle and I have to convoy down together.... Xtsix blew some injectors, possibly his IP and melted a piston also. he also won't be able to make it....
Don't forget I have a tote of oil for you.You can chuck the rope up in my truck........wait till you see all the pretty lights( and all the other new goodies).......muahahaha!!!
Bring your transfer pump and if you don't want to get yours dirty, then I'll bring mine but you will need to bring the strainer and nozzle cause mine does not have one... I can bring a extra empty barrel to swap with.....OH you couldn't drag that thought out of mind........Can't wait for the oil.......just have to figure out how we are moving it into my truck now that xtsix won't be there with his crane![]()
Park closes at 9pm and opens at 9am... u still can get in and camp but make sure you go to the office and check in first thing in the morning....Is there a time the park closes where I will not be able to get in? I think I will be getting in between 7pm and 8pm on Friday. I could not find anything on their website.
It is only 100 gal. We can just slide it from once truck to another. I will out it on the scale today to see how much it weighs. It is fryer oil straight put of the cookers.OH you couldn't drag that thought out of mind........Can't wait for the oil.......just have to figure out how we are moving it into my truck now that xtsix won't be there with his crane![]()
That also means the bathrooms are locked at that time also. . .Park closes at 9pm and opens at 9am... u still can get in and camp but make sure you go to the office and check in first thing in the morning....
Yeah, strap it good. last year I trail rode with all that oil in my truck.100 gallons, the thing will weight right at 700lbs for the oil and then the tote, maybe 50......should be able to slide it in......originally I was hoping to just off load you on the ground and then when I pack up put it back on my truck, I'll just have to strap it in real good so it doesn't slide around while trail riding...
how many relays do you want? I have some RIBs and ice cube relays. They are 10 amp max relays.Too much oil to just transfer to one drum, I would have to bring a couple of drums(space it getting too tight) cause then I have to pack them and the tote back up for the ride home......
I am bringing that 5 HP baldor motor is you are still interested in it.Too much oil to just transfer to one drum, I would have to bring a couple of drums(space it getting too tight) cause then I have to pack them and the tote back up for the ride home......
