ari
dacula Ga
Some spikes welded to it and steel grates over the windshield would complete it nicely. looks real handy for moving things though.
infidel got me
32
Newberry, Florida
My Humvee showed up last week and I've been working on it off and on. Work and weather permitting. Checked bearings and axle oil levels-- fluids etc.. Have a green eess box on order and I am changing the alternator over to a delco 21si. The current alternator is overcharging and I just don't trust the military alternators. I have one on my 5 ton and no issues so far.
85
Aurora, CO
It is, with the six switch source installed under the seat with the batteries.
I had a long conversation with them about it being 24v compatible, and they assured me it would work great. And so far it has.
Here it is rigged up to test some load with lights
jake-cutter
13
League City, Texas
Thanks that what I wanted to know. I had contacted them 6 months ago about being 24v compatible and never heard back. Now seeing that it can be hooked up to the 24v setup I will look at them again.
Bulldogger
710
Quantico VA
I made a grounding harness. Will have to wait to install until next week due to other obligations. Used 6 gauge wire from Home Depot. Had to use green bc they are perpetually out of black.
Made the connections from copper tubing, 1/4 and 3/8 for the terminations and one piece of 1/2 coupling for the engine block master connection.
Bulldogger
Lawdog734
128
Colbert, GA
I managed to paint the GMV this weekend. Overall, I'm very pleased - but it looks like the hood is going to need another 2-3 coats for sure.
86humv
538
Texas
No thread.
These are thicker rails, and galvanized.
I took apart a few and seen no cracks.
One weak area is between the 2 ears of the front upper A arm on lift tower.
Later towers added metal up top and filled in lower area which when bolted in, adds strength on rail.
