What have you done to your HMMWV today/lately
SmartDrug
310
Saint Charles, IL
The lift mechanical pump on the 1123 left me kind of stranded last week. Installed a Facet electric pump 4-6PSI and has been testing fine so far. Bought a new mechanical pump from HPG but will not install in the near future and when I do, i will leave the electric one in place for emergencies.
Used my jumper to start the truck with the 1151.
FAC-40151?
How was the installation?
KKroger
225
KC MO
One word of warning on Electric pumps they PUSH better than they PULL, so closer to the tank is better... Easier on the pump. Just makin count.
Gcelevator
804
Fort Lauderdale, Florida USA
FAC-40151?
This one. Installation was fast as i did not remove the lift pump yet. I am going through all the plumbing of the existing. I wanted to test 1st prior to the rmoval of the mechanical. Installed on top, right next to the power steering reservoir and used a switched wire from the instrument panel (don't remember which one i used, could it be a 27) something i noticed though, when i turn the switch on the pump makes a tiking noise pumping, but does not stop right away as my polaris MRZR (very similar pump) that leads me to believe the injection pump is not stopping the flow (all this prior to starting) and when it starts i see a little more black smoke than usual, of course it could be my imagination.
Thinking about it, of course the injection pump is not stopping it, it goes through the return.
[COLOR=var(--__dChNmAmGoMXsw4B,#0f1111)][COLOR=var(--__dChsbGMXsw4B,#2162a1)]
[COLOR=var(--__dChNmAmGoMXsw4B,#0f1111)]Visit the Store, DB Electrical
DB Electrical[/COLOR]
[COLOR=var(--__dChsbGMXsw4B,#2162a1)]Visit the Store[/COLOR]
[/COLOR]
[COLOR=var(--__dChsbGMXsw4B,#2162a1)][COLOR=var(--__dChNmAmGoMXsw4B,#0f1111)]4.8[/COLOR]4.8 out of 5 stars(8)[/COLOR]
[/COLOR]
[COLOR=var(--__dChNmAwPaMXsw4B,#565959)][COLOR=var(--__dChNmAwPaMXsw4B,#565959)]DB Electrical Solid State Fuel Pump 24V, 4.5-6Psi, 12" / 30.48Cm Min Dry Lift, 32 GPH[/COLOR][/COLOR]
Gcelevator
804
Agreed and noted. I am planning on going mechanical again and just leaving the electrical as back up where i just have to switch hoses and re-install the fuse to get back on the road if i get stranded. Well not sure what i am going to do yet to be honest, was just too lazy and it was too hot to replace the mechanical pump a couple of days ago. 😅
KKroger
225
KC MO
I actually have a Holley Red Pump on the frame back by the tank on a toggle through a relay for 12V...
After two nonfunctional Mechanicals... Just bypassed and left it. I'll just carry a spare...
DREDnot
617
Phoenix, AZ
Got a set of those 3D printed slider blocks that replace the rattly rollers in the X-door windows.
Took a little flat filing to smooth and fit the edges to my channels. No more annoying rattles while driving.
KKroger
225
KC MO
I might keep using electric. Did yoy remove mechanical at all and put a closeout plate in the place?
I removed the Mechanical completely. and put a closeout plate on there Just like on racecars of days gone by.
So Electric only and it is a bolt on an Easy plug and play... I can keep a spare in a vacuum bag in the Under Seat area...
Gcelevator
804
I was planning to make the closeout plate out of 1/2 aluminum plate i have.
Mogman
10,557
Papalote, TX
There was a big auction in CC this week, I looked at all the big stuff (ended up buying a Genie S-85 man lift) and the wife looked at all the "little" stuff that my ADHD does not allow me to care about.
So she said on one of the pallets she got for $30 had a couple really big Clevises on it, so I am thinking great, I can telegraph my sexual inadequacies by hanging a large clevis on my pintle hook :ROFLMAO:
BUT NOOOO, when she said big she meant BIG.
Behold a 65 ton clevis, 3" and the bolt is 3 1/8", weighs 157LB and new cost is over $3,000
I don't think I can get that on my pintle hook, although I can see a possible 2 1/2 receiver adapter for the 3500HD o_O
