What have you done to your HMMWV today/lately
spankybear
980
WA
It seems like it's all over the place. I suppose it's because I'm not stopping the pump at the same place every time.
I was shocked on how fast mine goes thought the fuel. Drive up to Skykomish and around Index and that's a half of tank. I haven't driven the LMTV much this year but just looked and filled it last September and it still have over 1/2 a tank... and it's been on the same Sunday drive a few time since. Granted the tank is twice as big as the my HMMWV.
I do enjoy driving the LMTV but every little thing I do to the HMMWV it gets nicer to drive.
Coug
4,769
Olympia/WA
I pretty much gave up trying to keep track of mileage in mine. Half the time I drive it it's either short trips, towing trailers, driving off road, or going through parades and such, so it isn't going to be consistent anyway.
The few times I did keep track, it was between 11 and 12mpg for just city and highway driving.
hgun
382
Leechburg, PA
Hello everyone. I just changed oil and greased the M1097R. But I have a question I’m sure it was brought up before, But I’m looking through the TM’s and I can’t seem to find the ones for the M1097R, So I have been following the M998 one. My question is I’m getting ready to change the transmission fluid transfer case. The TM shows Dexron 2 which I know to use what GM calls for now to use for that. But online I’m seeing not to use Dextron but to use AC Delco 10-4033 in the transfer case on the M1097R . Am I safe to follow the old M998 Dextron or switch. Thank you
Bulldogger
764
Quantico VA
That last time I read my TM it said Dexron III, which is near impossible to find. After asking others here, I have been using DexMerc without any noticeable issue.
BDGR
hgun
382
Leechburg, PA
I looked at what GM recommends for to replace Dexron III. And bought that. But figured I would reach out. Thanks for the info.
Coug
4,769
Olympia/WA
The M1097R is a recapitalization program truck, upgraded from a different version into a heavy variant. Not an actual factory variant of the truck.
If yours has a 3 speed, use M1097A1 in the manuals.
If yours has a 4 speed, use M1097A2 in the manuals.
Anywhere it says DEX II use DEX III. It replaced DEX II for all applications.
In the transmission you can use DEX VI, but not for the transfer case or power steering, as GM had a higher rate of failure in those applications for DEX VI. You can still use it if you want and it will operate fine, but may shorten the life of the components.
AC Delco 10-4033 , which is GM 88861800, is just repackaged DEX III for the places where GM had higher failure rates (manual gearboxes and transfer cases) after switching to DEX VI.
Snippet from the GM Bulletin.
bulletin - #04-07-30-037E: Release of DEXRON-VI Automatic Transmission Fluid (ATF) - (Apr 7, 2011):
"MANUAL TRANSMISSIONS / TRANSFER CASES and POWER STEERING
The content of this bulletin does not apply to manual transmissions or transfer cases. Any vehicle that previously required DEXRON®-III for a manual transmission or transfer case should now use P/N 88861800. This fluid is labeled Manual Transmission and Transfer Case Fluid. Some manual transmissions and transfer cases require a different fluid. Appropriate references should be checked when servicing any of these components.
hgun
382
Leechburg, PA
Well I got all the differential fluid changed new tranny pan filter gasket . Drained the T-Case. The TM says 3.5QT , But it came back out at 2 qt so I’m assuming that’s a typo on the TM. Any I’m getting closer. Next new hub fluid and check the nuts and new tires. Then replace the upper radiator hose and coolant and T-Stat.
Gcelevator
800
Fort Lauderdale, Florida USA
Replaced the 1123 front drive shaft, had the spare from the 1114 parts truck. The rubber bedding was destroyed. It looks like the one from the 1114 was never used, when y received the truck it was dissesambled and the blue paint on the splines untouched.
Mogman
10,505
Papalote, TX
The only caveat to what Coug said is that if your M1097R1 has a 4 speed and a GVWR of 10K (vs10.3K) it has A1 half shafts, hubs and springs and possibly drive shafts
hgun
382
Leechburg, PA
It has a 3 speed transmission . But the tag says 10K Heavy Variant. It does have half shafts. I got all the fluids changed except hubs and coolant. I just found it odd the T-Case took only 2 qts except 3.5. Im assuming im good when it started running back out. Thanks for the help
hgun
382
Leechburg, PA
Good evening guys. I’m looking for opinions. I’m replacing the tires. Do I reinstall the run flats or not. Some day they ride better without. But it wouldn’t be original. I’m not really worried about someone shooting my tires but then again with this world who knows. Let me know what you think.
Coug
4,769
Olympia/WA
if you are strictly on road/near roads, in other words not really taking it away from improved roads like the jeep trails, then it's entirely your choice.
You'll get opinions that these are death traps without some type of bead lock, and others that say they've run without them for thousands and thousands of miles with never any issue.
The 16.5" shoulder profile doesn't provide as secure of retention to the tire as more modern designs, but that's the only real issue. As long as you keep the tires reasonably inflated and check them often, there shouldn't be any issues.
If the tire does get low/flat, then you are much more likely to have the bead come off the rim, and that can be a major problem sometimes if you don't have things like a bead seating inflator to resolve the issue.
hgun
382
Leechburg, PA
Ok thanks for the info. I personally want to keep them in due the fact they were in there for a reason. After getting my butt kicked trying to install one back in a new tire. Started thinking and researching. I do not have a bead setter would have to use ratchet straps or starter fluid. I’ll continue to struggle lol only 4 to do. Thanks again
Coug
4,769
Olympia/WA
Once you get the hang of it, using a ratchet strap is actually pretty easy all things considered.
I keep saying it over on the wheel and tire shop thread, but buying some tire lube will make your life a LOT easier when removing or installing the runflat and the rim. Without lubrication you'll fight it for a long time, because rubber just has too much friction.
