vanaisa
- 407
- 63
- Tallinn, Estonia
Well, i may be wrong, but i always did coolant change this way:
drain from radiator (easiest to remove lower hose,if you have large pan);
if engine have drain plugs, from there too;
fill system with destilled water, run some 5 minutes;
drain again;
fill with proper coolant mix.
But this is your smallest problem right now. It can be done, when engine is running again.
drain again;
