HASSON1911
- 24
- 18
- roseau/mn
Subscribed, got a 923 to do this spring think I will go with Mike/wsucogarsx formula 383 CARC
100% concur with previous post.Thanks for the reply. I should have been more clear with the description of the existing paint. It is only peeling in a strip on the top of the front bumper. That area I would sand. Everywhere else is just the normal GM-clear-coat-weathers-off that is usually seen on vehicles from the 80s and 90s.My opinion would be that "yes, you will need to sand down the entire body", unless you want it to peel again. Think of it this way...if the clear is peeling in some places, it will eventually peel everywhere...it all came out of the same can and it's all exposed to the same elements. If you cut corners, you usually suffer from it. If you took a civi truck or car to a body shop because it was peeling in places, wouldn't you expect them to sand the whole vehicle before priming and painting? Also, I think the self-etching primer is designed specifically for metal. That may not mean that it won't work on plastic too, but most rattle cans indicate what they are intended for. It is going to be a lot of work regardless of what you do so you may as well do it right the first time. The latex house paint should give you the elasticity that you are talking about to a degree but if you really want something that will "stretch", use Elastomeric which is a latex coating that can be tinted to color of choice (make sure you get the smooth and not the textured unless you want a bed liner finish). It is pretty thick and tricky to spray but you can brush or roll it on with foam rollers just fine. Good luck and don't forget the pics.
Well, you will get back what you put into it. Even if it isn't peeling anywhere else, at the very least, you need to go over the entire body with sandpaper (not wet/dry). Something like 220 to "scuff" it. You could paint it without doing anything and it might look good right then, but it wouldn't last. The whole deal with painting is preparation...kind of like the cliché "pay me now or pay me later"..."sand me now or sand me later".Thanks for the reply. I should have been more clear with the description of the existing paint. It is only peeling in a strip on the top of the front bumper. That area I would sand. Everywhere else is just the normal GM-clear-coat-weathers-off that is usually seen on vehicles from the 80s and 90s.
I have no problem 220 wet sanding spot areas but the job is not worth it to me to sand the entire vehicle. Yes, it will be a short cut and I am OK with that. Again, this vehicle sits in a garage for a rainy day.
If self-etching primer is not the correct product to promot adhesion, I wonder is something like Krylon Fusion would work. Will it 'grab' paint like it grabs bare plastic?
Thanks, too, for the Elastomeric suggestion - I am not familiar with that product. WIll look into it.
That is the most painful part of refinishing. Hopefully the guy I am helping will see this and realize I am not kidding about the sanding every surface. His truck had been plastic media blasted inside and out, the paint that was applied peeled and chipped so I mandated 100% removal outside, then etch with phosphoric acid and pressure wash or sanding to make the primer stick.Well, you will get back what you put into it. Even if it isn't peeling anywhere else, at the very least, you need to go over the entire body with sandpaper (not wet/dry). Something like 220 to "scuff" it. You could paint it without doing anything and it might look good right then, but it wouldn't last. The whole deal with painting is preparation...kind of like the cliché "pay me now or pay me later"..."sand me now or sand me later".
I must be missing something here. You pulled dents out "AFTER" it was painted?I did an adhesion check with hot melt glue studs to pull some minor dents, the primer didn't peel but the dents pulled perfectly.
