CUCVLOVER
- 9
- 38
- west Tennessee, just outside Milan
Today I had to chew a round.
I had to swap out the old, box filter for a spin on unit. The old one was sucking air, and I could have plugged the hole for the pressure sensor (im sure tgat it was leaking) but when I'm in 4x4 low holding the peddle on the mat climbing out of a muskeg swap in Alaska I don't want to worry about is my patch on the filter going to work.
I used one from NAPA with 2 in and 2 outs and filter with a water separator made in.
I first tried the using the old filter bracket but the filter was on the valve cover. So quick fab job and done, I didn't have to lengthen my fuel in line but the line to the injection pump had to be longer, so I used a small clear fuel filter as a double Barb fitting/sight glass.
So now the truck runs great, at 70mph it starts to shake a little but I don't run that fast much.
I used one OUT for the engine and the other OUT for a valve to drain the air. I have a T that I can add later to have a pressure gauge too.
Thanks for looking
Thanks for looking
