cucvrus
- 10,501
- Jonestown Pennsylvania
Once again I received a set of oil lines from NAPA and they are both the same. 2 different part numbers but the same line. They are cheap yes and they will fit if I want tom half assed the job. I will keep looking. The AC Delco's were the same poor quality. I have a set off Amazon. I may just replace the rubber hoses on the genuine GM ones I have. I had Dormans that fit better but now they all seem the same. I would like them to fit so that I can get them into the bracket at the rear of the engine and not have them looking like a turd when I am done. Now is the time to do while the engine is on the floor. Have a great day. Watch out for poor fitting poor quality knock off parts. I think I will try Autozone. I have nothing to loose.First off let me say the fit of the NAPA oil cooler lines has a lot to be desired. They have 2 different part numbers but both look exactly the same. They both look like the forward/front oil line. Not even close. They are going back. I am going to order another pair and do a side by side comparison. I bead blasted the exhaust manifolds and painted them. Why not. They are back on. I cleaned all the other parts that go on the engine and installed a pair of energy suspension motor mounts into the clam shells of the stock motor mounts. Everyone know how to do the motor mount switch? If not I will post pictures. Tomorrow is another day. I have lots of work to do.
LOL !!! I don't think Rick ever sleeps !Looks great!
When do you sleep?
