- 802
- 916
- 93
- Bainbridge Island Wa
Soldered up loose radiator brackets.
Looks great, looks "legit"President Berry 2 with a biiiig amlifier behind on a simple 2.5ft antenna
Cutting, grinding, weld, repeat
I used the brackets that came with the grill but had to redrill the holes in the plates. You lose the d-ring tie down on the front.Looks good! Did you use the brackets that came with the brushguard and cut & drilled on one side (the outside)?
How did you secure the two outside bolts?Got heavy duty brush guard on me m1038. Still got some fine tuning to do
I have that same brushguard (Luverne copy) and it's perhaps the stiffest, it weighs around 75-100 lbs.I'm not even sure you need the outside bolts, its is a light weight and actually surprisingly very flimsy brush guard. flex a lot but look good
This is the heaviest brush guard made for HMMWV's. I have the other two that were made and this by far needs every bolt that you can attach to bracket. I used my forklift to hold it in place while measuring where the brackets needed holes to be redrilled. You can actually stand on this brush guard after its installed or use it as a bench. This is the flimsy one on my M1123.I'm not even sure you need the outside bolts, its is a light weight and actually surprisingly very flimsy brush guard. flex a lot but look good
Yes, it can flex about 1/8”? It’s solid flat steel bar, if this is flimsy, then the other brushguards would maybe fall closer to the cardboard categoryI have that version and you can flex it with your bare hand a inch in either direction at the far edges
I’m still fine tuning mounting. Plan is to put 2 4x4 steel tubing 1/4 in thick behind outer 2 bolt holes. Using 2 grade 8 bolts 1/2 in 8 inches long to bolt through tubing into existing holes in tie down frame mount holes. 2 outer holes line up just fine. It’ll be strong enough. Don’t plan on securing to aircraft deck or winching up a tree. Pictures will follow when done.
Also these early m1038 use a different winch plate compared to later ones so I had to adapt and overcome any hazards without loosing my shit.
Dont know how it called in english... you dill a hwole and press in a nut. So i can remove it with two screws and still have a flat surface
I have solved Bloutooth via the intercom. A small BT receiver supplies the "radio in" of the intercom distributor.You know I could see expanding this cool setup to include an audio amplifier with Bluetooth, Four 5 1/4" coaxial speakers. Four USB charger outlets for both "C" and 3.0 USBs. That center compartment for me could hold my four aircraft intercom headsets.
Any bluetooth operation would be controlled by a radio tray mounted 10" tablet. Hell could even put a small lythium battery/batteries to make the whole thing portable. I really like the possibilities and the size is perfect. Hats off on this use of a 120mm ammo can.
Mark
Sounds like a Rivnut (rivet nut). Common fastener on our trucks.Dont know how it called in english... you dill a hwole and press in a nut. So i can remove it with two screws and still have a flat surface. The screws are in the lockable compartment, so that it can not be easily stolen.
If you get new ones I'm sure they will be fine. Mine were pretty weathered, looks like they spent years sitting in the desert sun.Funny... I got exactly these two-piece new for mine. Because they simply fit better to the vehicle.
