FLU419 SEE HMMH HME Owners group
Another Ahab
4,204
Alexandria, VA
New pump has arrived from expedition imports. I was able to find the actual failed component on sites that apparently only sell to retailers. So of course I was disappointed that I had to spend $170 versus probably a couple bucks for the failed piece. I can't wait to install the replacement this weekend and finally be able to bring this beast to life.
It's a hit, sure, but considering it got your SEE operational?
- Fuhgeddaboutid, we all learn as we go
Glad you got the problem solved. :driver:
mberetta
Utah
I'm just one who likes to replace the failed component when possible. The cast housing, spring and push rod are all still perfect. Oh well, they're headed for the spare parts bin... ...I mean shed.
Sent from my Moto G (5) Plus using Tapatalk
anthkey
Cumming ga
I have four tires and rims looking to get rid of! $100 each ...
anybody interested? Great tread... I just upgraded to big mud tires since I’m not taking it on the road ,using it on my 16 acres ... pick up only preferred I will travel 50 miles to meet you ... zip 30040
The FLU farm
1,239
The actual midwest, NM.
Hey, For all you HMMH folks out there, how high above ground can you get the hook of the crane?
If memory serves me, max height/reach is 22 feet. Of course, at max extension the stated capacity is only 2,000 lbs.
And I need to go look at the decal and see if that's max height, or the height of the hook. Stay tuned.
The FLU farm
1,239
I remembered correctly, sort of. The 22' is without extending the boom.DSCN2771[1].jpg
And it looks like they're measuring from where the hook attaches, not at the hook itself.
hrbergeron
379
Geographical Center of Virginia
Used my war digger yesterday to unload a generator out of the back of my 2500. Had to lift it with the backhoe then use the forks. If anyone needs a MEP-003A, this one will be for sale soon.
Pinsandpitons
41
Central Washington
Same kinda deal here, not sure how much that blade weighs, but is in the neighborhood of 2200. I recently excavated and moved about 40 yards of material 300 ish feet and it made things much better to leave the backhoe up. The weight of a full loader bucket is nicely counter balanced with a deployed backhoe.
DM3
Patten/Maine
Town: Pattern
State: Maine
email: ​dmims@hughes.net
Phone: upon request
Will send frame No. when on next reply
The FLU farm
1,239
These new posts, combined with my conscience, made me fire up the Winter SEE and move some dirt today. It's been on my mind for a while, because it hasn't been started up since the snow blower came off in...what, March?
Much to my delight, the air pressure gauge still showed 60 psi, and it started instantly. Life is good.
Of course, with a low of 31.1 last night, the next time it gets started could be to put the snow blower back on. Guess I should've just left it on there.DSCN2785[1].jpg
